squeaky EBCs
    squeaky EBCs
    about a month ago i put brand new ebc green pads front and rear and they squeak like 5yr old pads.
    my question is is this normal? maybe somethin to do with the break in layer?
    Its drivin me crazy and im about ready to cut the squealers off but ive only put like 100 miles on them so
    any input is appreciated
    http://www.cb7tuner.com/vbb/showthread.php?t=187851
    sold to: cb7rush\h22-accord\Luis\BurtonRiderT6
    bought from:jokerxfn-tommi-'93cb7ex
    I put Grease on the Guide bolt, the back of the Pads(not the front) and the part that holds the pad in the Caliper. I never had a problem after that.
    http://image.superstreetonline.com/f...eak_grease.jpg
      those arent the squealers that are making the noise. did you de-glaze the rotor?
        i pulled everything apart cleaned and regreased man was there ALOT of dust it seems to have gotten quiter but still squeals
        B.T.W all four rotors were replaced at the same time with brembo blanks
          could it be you bearing or bent rotor? not sure just a suggestion.
            I also replaced the bearings with genuine parts when i did the brakes, I went through the break in proceedure with the rotors and theres no shake or shimmy when breaking its just buggin the hell outta me with all the money ive got into it and sounds like nails on a chalkboard
