So, went to a junkyard this past weekend, found myself some Legend dual piston calipers for a whopping 27 dollars. Also previously swapped out the rear drums on my car for rear discs off an Acura Vigor. Just recently I realized my car had the wrong front brakes, since I have a wagon and someone put sedan/coupe rotors on it...
So, swapping over to Brembo discs in front, Hawk pads, and the Legend dual piston calipers. Gonna wait on pads/rotors for the rear, just stay with what it has for now since they work fine.
Anyway
1. What kinda proportioning valve is best for this setup? I've heard a 40/40 proportioning valve off of something is what you want when you just swap rear drums for rear discs, but I also know that with the big brakes and dual pistons in the front you want something different, and I'm not positive what you want since this is being done on a wagon which had the big brakes from the factory.
2. Is the brake pedal always kinda squishy on cbs? Not saying that it's really a problem by any means, but after driving my mom's 2012 Saab, I realized that my pedal goes down a LOT easier than that one and I'm not sure why. So I mean is that just the design of the pedal, or is there a part of the braking system that's getting worn, or something else? Perhaps going back to the junkyard for the brake booster/master cylinder for the legend type 2 would help me out on that?
Anyway
