I decided recently to do a rear disc swap on my 92 Accord LX wagon, after several of the wheel studs in the rear snapped when I went to put on new tires. And then upon inspection I found the drums and shoes to be worn. Since I know nothing about drum setups, I went to the junkyard to get the parts for a rear disc swap. When searching the yard, I found only one 90-93 Accord with rear discs. And of course both calipers had been taken, along with the hub and rotor on one side. And whoever removed the calipers was too lazy to unbolt the e-brake cable and the brake line so those were cut. So I didn't go with it. Kept looking though, found a 94 vigor they didn't have listed, with the complete rear disc setup intact. Looked pretty similar, so about 2 hours later I left with the whole rear disc setup and the rear sway bar for 90 bucks.
Anyway, I just successfully replaced the rear drums on my 92 Accord LX wagon with the trailing arms, knuckles, sway bar, and most importantly, discs from a 94 Acura Vigor. Then I did rear Koni Yellows, and green Tein lowering springs. Still some kinks to work out (a couple noises I haven't identified, could be a bad wheel bearing or strut mount or the tein springs breaking in or something), but it does indeed work. So far, I have no idea if there is any rear advantage to the vigor brakes. The one thing I have found out is the height of the Accord rotors is 48.6 mm, and the height of the vigor rotors is 63.6 mm. So it's like I just threw on a pair of 15 mm spacers. Wheels are sitting pretty much flush with the quarterpanels. Looks decent, would be better if the panels weren't so rusty.
Anyway, if anyone else is planning on doing this, there are only a few parts you need from the old setup.
Accord left brake hose bracket. The one that is up near the gas tank
Accord e-brake cable brackets. None of the vigor ones match up.
Haven't attached the e-brake cables yet, so I can't confirm if it works or if it is a bit too long. May need the accord e-brake cables. Not positive, can't confirm.
Also, the right rear of the car is making what seems like some rubbing noises if I turn left significantly while at speeds above about 20 mph. Any ideas?
