bleeding abs brakes
    bleeding abs brakes
    im going 5 lug using Odyssey parts and im wondering if having abs brakes makes it different from bleeding non abs brakes. i need to replace calipers and want to make sure i dont fuck it up because my car is a dd. is the same RR LR RF LF? or do i have to mess with the abs modular/pump?
    COUPE K24
    nobody?
    COUPE K24
      No. The abs brake fluid system is completly seperate from the normal brake fluid system
      Bleed the car like a normal car and everything will be fine.
        nice.
        COUPE K24
          Funny thing, was installing On Demand 5 today and looked at the brake bleeding sequence. LR,RF,RR,LF is the correct way.
