NSX caliper swap
    Originally posted by Jarrett View Post
    http://www.fastbrakes.com/product_p/accordtsxrl.htm
    http://fatfourcustoms.com/newest_pro...7_honda_accord
    These are radially-mounted calipers going onto knuckles meant for standard-mount calipers.
    That's it.
    Be unique, like every other person.
    CB7 Sold________________________E34 Sold________________________E39 Current
      Basically what Jarrett said.
      In addition to the calipers and FFC brackets, if you are 4-lug, you will need to upgrade to CL ROH front knuckles/hubs. For rotors, you use ones from a '06 Nissan 350Z Track Edition (aka the one with Brembos). You will have to have them re-drilled from 5x114.3 to 4x114.3.
      If you are 5-lug, then those rotors are pretty much a direct bolt on...you just need to dremel out the center hub of the rotor a few millimeters, to get it to clear the hub.
      Otherwise, everything just bolts together, and is actually a very technically simple swap.
