I'm making this post to confirm the setup (I talked about in the post I made previously) works fine with absolutely no issues. Stops great!
What you need is:
stock 25T wagon brackets from a 91-97 Accord
282mm 91-97 Accord wagon rotors
NA1 3.0L NSX calipers
4th/5th gen Accord wagon/5th gen V6/NSX pads (they are all the same)
Not needed to make it work but the dust shield from a wagon would be nice too as the stock shield is smaller and needs to be slightly bent to ensure it doesn't rub the rotor. We didn't change the shield.
Everything else is stock or equivalent to stock (ie SS brake lines meant for 4th gen Accords, hubs, bearings, etc)
What you need is:
