Stipped brake bolts
    Stipped brake bolts
    I stripped these 14mm bolts on the hub assembly to the brake disc trying to replace the rotors. is there any way i can remove them? should i just bring it to a shop so they can remove them?
    how bad stripped? rounded the corners or complete made it a circle?
    COUPE K24
      its a little rounded around the corners. It can still grip a little bit but as soon as you start torquing it down it spins.
        http://www.amazon.co.uk/dp/B000QW6K8...SIN=B000QW6K8I
        I assume you have the equivalent to these in the US? For something like this they would work, I have a set works well in some situations.
        UKDM 93 CB3 Page (1) H22A U2Q7 LSD
        UKDM 91 4ws Page (3) OEM Minter
        NOW H22A U2Q7 SWAPPED
          Get a snap on 14mm wrench
          COUPE K24
            NICE! that made me get up and drive to the nearest Home Depot and purchase this for $20.00
            I will give it a try tomorrow
            it wont fit because of the hub. the bolt is deep inside the hole
              ^ ah. nevermind then.
              COUPE K24
                does anyone know the part number of these bolts? i dont understand the diagram of which bolt is pointing where but i am assuming its number 22?
                  looks like #22 to me. did u get them off??
                  2013 Ice Cream Cruise!
                  VIDEO: 2012 Ice Cream Cruise
                  August 3 ~ Omaha, NE
                  By 1320 Video
                  Member's Ride Thread
                    good man, hope they worked out for you
                      hey man i just wanted to say that IRWIN stripped bolt remover works wonders and i highly recommend it for everyone to have in their toolbox. i changed out my bolts and now i'm riding on new rotors. Woot woot!!
                        excellent news, 1+ rep point for me then
