Affordable Pad upgrades
    Any decent upgrade pads out there anybody recommends? I'm still autotragic and I ride the brakes a little more than most when entering a corner in overdrive than you gear jammers
    I have hawk pads on my prelude. I wouldn't say there affordable, at about $50 a pair, but they stop on a dime. I'd recommend them if you don't mind brake dust, lol, because they aren't the cleanest pads, either.
      Any pads with a lifetime warranty.
      1992 Accord Wagon (RETIRED)
        What do you consider affordable?......To me 200 dollars for great brake pads is affordable....Im looking into getting EBC redstuff brake pads.....but the EBC greenstuff should be good for you....and they arent overly expensive
        Burrito Bandidos: It will change your fuckin life
          Duralast ceramic, not sure about warranty but 38 buck at auto zone.
          "The Turtle"
          DD/Trail Rig/Mud Bug
            14.99 brake pads work just fine for me!
              Just picked up aset of Reybestos ceramic for the front =47 bucks
              Check Out My Work In Progess . . . . .
                Try Auto Zone if they are in your area. I believe they still have the life time warranty on pads and all replacement pads are free for the life of your vehicle with your receipt.
                600HP" 1990 ACCORD LX COUPE COMING SOON
                CLICK HERE TO VIEW MY 1990 CB7
                  x2 and virtually dust free
                  smoke tires, not drugs.
                    raybestos ceramic pads, Beck arnley rotors on the front and the wagon stops respecfully well.
                    Soon too come, 11" prelude rotors on the rear (drums now) and 98 camaro calipers . this should help with brake fade i would think
                    good performance can be achieved as long as everything is in good servicable condition, i can say that the ceramic pads take some time to seat but the performance after is better than metalic pad, only issue is the rotors get beat up pretty bad. probably need replacement when the pads wear out but well worth it.
                    96 Accord SiR driveline installed. CF2 donar
                      Originally posted by cb9wagon View Post
                      98 camaro calipers ..
                      Do tell. Custom?
                        no no no...lifetime pads are trash. They tear up your rotors too.
                        Think about it...SOMETHING has to give...your pads or your rotor..which would you rather? Your pads should NOT last a lifetime as they are SUPPOSED to wear!
                        Brake dust is not the sign of a poor pad, it's the sign of one doing it's job.
                        ____
                          I have "The Best" that kragen sells. It's for about $60 with tax. Plus I also have bear brake rotors that are drilled and slotted. Honestly I don't feel a difference but then again I never did a test for before and after. Overall the brakes work fine. My friend who owns a DA says my car stops solid compared to his car.
                          http://www.cardomain.com/ride/2620526 190E Mercedes Benz
                          http://www.cardomain.com/ride/3065882 Accord Under major Repairs
                            "Warranty Excludes Wear"
                            The warranty is for things like shims getting eaten (this happens to me all the time)
                            Or occasianally those cheap brake pads crack and break apart.
                            Right now I have Nissin pads on the front and Carbon Metallic on the back...
                            Integra LS Proportionin Valve and 91 SE ABS Master Cylinder
                            It stops quick(given my rotors turn to mush)
                            Your man for wiring solutions!
                            CB7Man's Coupe H22 Swap
                            CB7Man's Sedan Resurrected From The Dead
                              all I do is say they're defective. I've got autozone pads in the back, I've gone through about 3 sets of the "Gold" pads w/ paying for just the first set and all i do is say they're cracked and make some BS up and they give me a new set of pads.
                              But for the front of the car, I have Hawk HPS pads. REALLY good pad for the money, they do cost about 65 bucks but they stop the car really well w/ minimal fade. I've got an Acura Vigor brake setup in front, identical to the Prelude VTEC 11.1 inch rotors except its Hub over Rotor so its still a PITA. One way to go to avoid paying 300 bucks for CL Rotor over Hub conversion.
