Looking at the driver side rear tire from the rear of the car you can see that the camber and toe is off. I had a honda mech. look at it and he said it had something bent in it. So off to local pull a part and removed the hub assy. along with trailing arm and the (rear lower control arm, I think that is what it is called) Now my question is there are 2 arms that come from the center of the car and connect to the rear oh the hub/spindle the one in the rear came off no problem but I could not get the front one off. I did get the nut off and noticed it had a eccentric washer on the nut side but the bolt would not come off. Any help would be appreciated.
Need Help rear camber and toe off
Originally posted by johnlThe bolt will probably punch out with a drift (any bar with an OD a bit smaller than the bolt).
The eccentric washer is the toe adjuster cam.
I can comfirm that the washer is to adjust the toe
----------------My 92 Honda Accord LX---------------------- My 97 Nissan 240sx LE----
NE GUYS, Buy the last of my accord parts
