Prothane Bushing Kit - rear lower control arms
    NOTE: For anyone installing Prothane rear lower control arm poly bushing kit, after removing old bushings from all lower arms, do the following:
    - press in Prothane outer metal sleeves only (leave bushings out)
    - media blast the outer metal sleeve area to prepare for welding
    - weld 2 strips per side of outer sleeves, 4 total per bushing and 8 total per arm, for a grand total of 32 welds
    - paint each bushing area with anti-rust paint
    - moly lube & install bushings with inner metal sleeves
    - continue with lower arm installation
    If you do not do this you risk the rear lower control arms sliding along the Prothane bushings do to loosing the "[press-fit", as I caught while my car was on the hoist.
    I just ordered this exact kit in preparation for my suspension overhaul, thanks for the tip.
    Just to clarify: Weld ~1/2" bead along the outer "arc" of the bushing sleeve so you have something that looks like
    () LCA
    with "(" and ")" being welds. and "" being the sleeve?
    My Member's Ride Thread
      I'm more visual...will re-read...but anyone got pics of this?
      ...or maybe a pic showing where to weld...?
      ____
