koni yellow question..
    Someone locally is selling a set of Koni Yellows for a 97-99 acura 2.2 cl.
    are these the same as cb7 koni's cuz he's claiming they will work for 90-97 accords.
    i'm like 95% positive they are the same
    ~~~~~~~~~~1991 ExR alb F22a6~~~~~~~~~~
    part numbers are the same according to the neuspeed website
    Burrito Bandidos: It will change your fuckin life
      yeah if the part numbers are the same then it should be fine...but just to make sure, check koni's site, not neuspeeds. Neuspeed has special koni yellows with more height adjustment grooves, so the part numbers could be different. I doubt it, but just to be safe.
        Does the 97-99 acura 2.2 cl have Mac struts or double wishbone? If Mac struts then I can't see them fitting, if double wishbones then still check the part numbers. The CB7 and CD5 Accords run the same suspension I understand, so they would fit both these cars.
        Regards from Oz,
        John.
          they will fit they use the same suspension as the cd accord so we can use them. I've searched on acurazine before so they will fit.
