need suspension advice!!!!
    ok guys so i am buying the neuspeed supercup kit, but i am not getting the race springs. i am getting the sport springs for now that is.
    anyways. while installing the suspension i am also changing a wheel bearing the lower ball join<<<(autozone ones). i am also puting new brembo rotors and replacing all botls and nuts.....
    while i have the suspension out, is there anything else that you guys would suggest for me to replace???
    anything!!!!
    i have helped my friends do suspension work on nissans civics etc etc but this has been a long long time ago(in 2000)
    do you guys have any advice for me relating to the supercup kit(sport springs)
    do i need to cup the bumpstops with the sport springs
    do i need to do an aligment as soon as posible or should let the supension settle for a couple of days....
    do i need a camber kit with the 15" wheels. although a lot of people say no... i want to hear fromt he people that actually had this suspenison. (specially you h23accord) lol
    etc etc etc.
    ok guys shot. i am very open to suggestions and ideas.
    Im not sure if you need to cut the bump stop with the sports but I have the races and I cut mine and the ride is the same as stock pretty much
    Get an alignment as soon as possible
    I have 15" wheels with no camber kit and Ive had zero problems....Again this is with the races not the sport springs
    Also when the suspensions off just replace everything you can afford to replace...Even if its just one bushing itll make it easier on you later on down the road.
    Edit: After re-reading your post I get the impression your gonna go with different springs later on?...May i ask why change?
    Unless I mis-understood your post then ignore the edit lol
    Burrito Bandidos: It will change your fuckin life
      well i want to try the sport springs first because of a few reasons. the driveway to my garage is on an angle. the road to my university is under construction etc etc etc. i just want to know how they feel. if i feel i need a stiffer springs then i will go with race.
        Go for polly or replacement bushings if you an afford it.
        If you drop to the race setup you might want a camber kit, I always get people telling me to get one. But there are plenty of people that don't have one. So I guess that's up to you to decide.
        Click for my ride thread.
