Tein Super Street w/Pillow Ball Upper Mount
    Hey everyone,
    I want to upgrade my stock suspension (just about 290KM old) with something that has better ride quality than the worn out stock Honda springs/dampers. I'm not interested in dropping the car, just a solid, smooth, quiet suspension set up for every day use. I was wondering if any of you have experience with the Tein Super Street w/Pillow Ball Upper Mount suspension? If so, how is it? How does the ride height and quality compare to stock? Is this the best setup I can get within a $2000 USD max budget?
    Thanks!
    The pillow ball upper mount won't offer any useful adjustability. It's a good system though.
      $2000 usd max budget. You can do a lot. Get some Eibach sport springs and KYB GR-2 struts. Then get all new upper control arms, lower ball joints, new bushings, and tie rod ends. Then you will be riding like new.
      Gary A.K.A. Carter
      [sig killed by photobucket]
        That's true. You're better off replacing the front suspension components with new stuff before you go nuts on the suspension. So few actually do that.
        If you can spend $2000 on suspension, replace all your components with new OEM parts, and spend what is it, $750 for Form and Function Autolife Type 2 coilovers (check the sticky in the classifieds section). Get a camber kit, and you're set!
          GR2's on any sort of drop springs is a bad idea.
