Im throwing my coilovers on from my other cb7 that i got into a car accident with onto my new cb7. But since the suspensions off and i dont have a camber kit i wanna buy one now. So whats the best one to buy? Should i worry about the back at all? Best sites to buy one from? Any local shops?
Camber Kit
Originally posted by Haccord21Where can i get these? Most the sites i go to i only find kits for integs and civics. i know im lookin in the wrong place. can you guys help with that?
Originally posted by Haccord21whats the difference between negative camber and camber?
/----\ Basically, the wheels lean in
Then there is postive camber, which looks like this
\----/ The wheels lean out
For a DD, you want 0 degrees of camber, which is both wheels perfectly up and down.
its easy if you got stock replacement or if you got struts and springs as a complete set. I bought struts and springs separately, and it was a nightmare. It took me and my bro a full day to get my rears to fit right. The fronts were easier, but it took some "persuading" to get the struts into the forks. Its well worth it in the end, and go get that alighnment. I still havent gotten it, and in about 2000 mi, a brand-new set of my khumos are as smooth as a babys ass! Of course,i started with 1 1/2 in, then said f-it and stayed with the 2-1/2in drop.
I've had the ingalls +1.25 to +3 deg anchor bolt kit in for the last 6 months or so as the car was pretty low. Good solid kit. I've now bought the ingalls -1.5 to +1.5 ball joint kit as I've raised it up a bit. Have yet to install it. Looks good though.
I've bought from this place both times. They've given great service. Shipped the stuff to australia in less than a week both times. I've gone through their ebay shop both times as the prices there were lower.
Thanks guys. I already have a set of drop zone coilovers so im not sure if there gonna be hard to replace or not. for the front im replacing prety much the whole hub if thats what you call it. changing the front brake, suspension so i just was wondering if it was easy to replace that all. im doing this next week thanks for the help and ill let you guys kno how it goes when im finished.
