Alright so as some of you may already know, I recently purchased a set of USED Tein S-tech Springs.. I have heard some different things about these and would like to seperate the fact from fiction with a couple questions...
1. Can I use my stock shocks/struts with these springs? I saw somewhere that the stock shocks/struts WILL NOT blow with these springs because it is a mild drop.. Is this true?
2. Other then an alignment, and camber kit what else will I need to install or remove with these?
3. Will I need any special tools besides a spring compressor to install these?
I am not worried about the install, I just want to make sure that I have everything that is needed before I am to start taking the stock springs off and then realize I need another tool for something else. Any help would be appreciated.. LMK... Thanks in advance.. Later
