problem with camber after aligmnent.
    I jus got my camber installed today, n for some reason one side is higher the the other. I have skunk2 coilovers which are all adjusted at the same height. I dunno wuts wrong. Also the ride is rougher wit the spc camber kit, but i kno dats the control arm. Any suggestions wut could be the problem with the height?
    ILL MENACE
    well, when i installed the camber yesterday wit mauricio, the ride height was still strange and uneven. I got the aligment thinking it would make a difference on the ride height but it didnt. Could it be that it has to settle, or is somethin wrong?
    ILL MENACE
      How much of a difference are we talkin? Coilovers don't settle AS MUCH as springs. However, they do settle.
        my driver side is a full 3-4 finger gap, while my passenger side is like a 1-2 finger gap. its really a big difference n its noticeable!
        ILL MENACE
          ride height was fine until i installed the camber kit yesterday, i even got the aligment today, but dat didnt work out.
          ILL MENACE
            is it messed up in front and back? or just one corner is screwed up? Did you put a bump stop on one side and not the other? Maybe the spring isnt seated correctly in the ... top or bottom parts.
              well one of the bump stops was lose so on the side dat is high, n i kinda jammed it in there before puttin in the camber, u think dat would make a difference? and yea its the driver side only. It was all fine until the camber was installed.
              ILL MENACE
                Any suggestions or ideas anyone? could it be on of the bump stoppers caught n jammed?
                ILL MENACE
