So I'm jacking up the car for the swap. Move to the passenger front and start taking off the lugs. Get to the last one and the whole stud and lug are turning . So I realize that the stud is obviously broke off from the hub and I can't get the lug off because it is not fixed to the hub. So the problem is now what to do. I remember when I did my civic swap that I could have left the axles on when I pulled the engine out. So what am thinking is to take the axle nut off and when I pull the engine out the axle with the broken stud should come off. I need advice pleeez.
Helllllllllp!!!!Front lug stuck;spinning
