Electronic Coilover Suspension Kit
    Has anyone had any experience or heard anything regarding the JDM electronic adjustable coilover system pictured below?
    Electronic Adjutable Coilover Kit
    600HP" 1990 ACCORD LX COUPE COMING SOON
    CLICK HERE TO VIEW MY 1990 CB7
    YOu must be talking about the control units like the EDFC and such that control your damper settings. Most of them work like that anyway. I dont think they adjust height but I saw one do it but i might have been trippin. But its good for dialing in your damper setting so when you go to the track swap to that setting then after that you can put your setting back to DD style when your done at the track.
      I just came across the coilovers on ebay. I included the link after the pics in the original post. I just never heard anything about them and the coilovers in the original link are for CB7s.
        Here it is its called: TEAS stands for "Tanabe Electric Active Suspension" and is the counterpart of the new Sustec Pro SEVEN suspension
        http://www.tanabe-usa.com/coilovers/TEAS.asp
        Sustec Pro SEVEN
        TEAS (Tanabe Electric Active Suspension)
        Sustec Pro S-S
        Sustec Pro S-S Type II
        Sustec Pro S-OC
        Sustec Pro S-OC Type II
        TEAS stands for "Tanabe Electric Active Suspension" and is the counterpart of the new Sustec Pro SEVEN suspension. This compact unit is the 'brain' behind the highly sophisticated new Tanabe suspensions. TEAS is a fully programmable dampener controller that allows for dampening force to be automatically adjusted while driving. TEAS accomplishes this by connecting and using the signal from the vehicle's Speed Sensor.
        Remote dampening control from within the vehicle is not a new concept by any means. In fact, many Japanese vehicles from the 1980's including the FC3S RX-7 and MA70 Supra had buttons to change dampening from "Normal" to "Sport." Unlike other controllers that are simply an update of this older 'analog' technology, TEAS is a much larger step towards highly digital advanced suspension control and tuning through it's speed sensing "Active Mode"
        TEAS active dampening control is uniquely possible due to the use of the specialized valving of the SEVEN, in conjunction with TEAS' slim, high speed actuators. These actuators change dampener settings in 1/100ths of a second, which is necessary as TEAS can continuously change settings at different speeds.
        Exclusively for use with Seven & Future Tanabe suspensions!
        Active Mode
        This mode takes readings from the vehicle speed sensor to automatically make changes to dampener settings for the front and/or rear of the vehicle.
        When programming TEAS, you may program up to 9 'triggers' that occur when you reach a variety of speeds. Iincrements of as little as 5mph can trigger a dampener setting change.
        Once Active Mode is programmed and turned on, TEAS will automatically adjust settings as your drive.
        Function:
        For any road, be it a circuit, city street, or winding road, there was usually never one single 'perfect' suspension setting. One dampener setting could be good for one high speed turn, and then it would cause understeer on a lower speed corner. This concept of suspension setting is changed with TEAS Active Mode, and allows drivers more control, and less compromise on performance.
        Because handling characteristics change within fractions of a second, it would be nearly impossible to attempt manually adjusting while driving. TEAS is a different concept due to high flexibility of the ACTIVE MODE, since the suspension will continuously adjust according to how you chose to program it.
        When TEAS is in Manual Mode, dampener settings will stay fixed to the points they are set at. Up to four memory slots may be used to store Manual Mode settings.
        Manual Mode allows front or rear dampener settings to be individually adjusted by manual input, or recalled from any of the four saved settings..
        Additionally, Manual Mode settings can be used as 'base maps' from which the ACTIVE MODE programming can work off of. By simply pressing the button to switch to Active Mode, TEAS will be able to actively use any of your four saved manual mode settings.
        High Speed Actuators
        Because the TEAS unit is an ACTIVE suspension controller that can continuously change dampener settings, the speed of the actuators is key. Active changes in suspension need to be quick and immediate upon reaching the programmed 'trigger' speeds, so TEAS actuators are designed to change settings in an amazing 0.013seconds. (1/100ths of a second)
        Exceeds OEM standards for quality
        Every component of SEVEN and TEAS exceeds OEM standards for quality. Some new luxury vehicles have actuators on their suspensions to switch from Normal to Sport suspension, TEAS' actuators exceeds these automakers in quality and reliability. The ultra slim profile actuators have a protective boot to protect the intricate inner working of the actuators, for flawless and accurate operation. These ultra slim actuators are made of metal, instead of the bulky inexpensive plastic used by some competitor brands.
        Ultra Silent Actuation
        Since TEAS can continuously and automatically change dampener settings, quiet operation is a necessity. Other manufacturers have extremely noisy actuators since their units are not active, and must be manually adjusted. TEAS has settings to have an audible beep for dampener changes, with volume settings, and logically, an OFF option for quiet operation.
        Memory Storage
        TEAS uses onboard flash memory to store settings. This onboard memory means that memory settings can be saved and recalled, even when the battery is disconnected. TEAS can store four manual mode presets which also work as Active Mode 'base maps.' One Active mode program may be saved for a total of Eight settings. TEAS also has backup memory onboard, should you wish to restore default settings.
        Speed Signal Sensitivity Adjustment
        TEAS is a passive system that connects to and reads many different speed signals, and has calibration options to adapt to the speed signal of any vehicle. Since many cars are equipped with aftermarket stereos, amplifiers, and other hi-interference devices, TEAS has the option of adjusting sensitivity, to prevent getting false electronic signals and interference from these types of devices.
        High Contrast LED Backlight
        TEAS uses a high contrast LCD display for easy reading. Blue LED backlights can brighten and dim for simply, trouble free night and day useage.
          I actually thought about buying awhile back when i 1st saw it but theyre was available reviews about it.
          1993 Accord LX - Sold
          93 BMW 525it - SOLD
          92 Accord EX Sedan - SOLD
          2000 Accord Coupe - Traded-In
          2003 Accord V6 6spd Coupe - Sold
          2001 Honda Civic Ex - SOLD
          2013 Chevy Traverse LTZ - Kid hauler
          2003 Acura Tl 3.2 - Daily Commuter
            thats kool, but i dont see myself paying all that extra money for a device that turns the knobs when i can just get out of the car and manually change it. Sure it will store 3 different settings taht you can program, but i dont think I would need that. I guess it all depends on your driving style and your wants/needs.
            Formerly 91AccordExR33
            11.68 @ 127mph
            417whp/375wtq
            Sold: 8/2016
              Well, I was talking about the full kit from ebay that already comes with something similar...dont think its digital but it would work...plus it only $600 just like all the other coilovers..only - side is that its a no name product.
              93 BMW 525it - SOLD
                I could see if it lowered the springs lol then that would be better. but its jus loosening and stiffening. Still a good find.
                Cali.Dumps.Harder.
                  loosening and stiffening, but you dont have any readout of whats going on with your dampners. Personally i would hate trying to dial it in and trying to remember what i did with my suspension last time. Although it is only 6 settings, i have the memory of a brick wall. Looks to me like ebay is getting high-tech while still maintaining its cheap crap reputation. and charging more for it.
                  BUT
                  you never know. could be a great ride.
                  so whos gonna take the plunge and test these puppies out? Accordtunerzz, i choose you! you're forever changing stuff anyways on your car, be the cb7tuner.com guinea pig!
                  CB7tuner.com Appearance Specialist - PM me with any bodywork questions
                    I am going to order an EDFC for my friends lex Ill let you know how that goes ha. But its gonna be a while. He has a set of Tein Flex on his car.
