the steering wheel gets real shakey sometimes when im driving. got some anniversary wheels and newer tires and it still does it. on my old set of tires the front drivers side tire was damn near bald but the other three i could probably get another 3000 or 4000 miles out of. could i get an alignment and get this problem taken care of or is there more to it than just that?
steering wheel shakes
Originally posted by 90_cb7the steering wheel gets real shakey sometimes when im driving. got some anniversary wheels and newer tires and it still does it. on my old set of tires the front drivers side tire was damn near bald but the other three i could probably get another 3000 or 4000 miles out of. could i get an alignment and get this problem taken care of or is there more to it than just that?
exactly. you could also take a look to see if anything just stands out.-1992 Accord EX H22 234whp 185wtq
-1993 Accord EX SOLD
-1995 Accord EX Wagon Daily Driver
-2012 GMC Canyon V8 4x4
My wheel shake was caused by bad alignment. (shake as in moving left and right about .5 inch rapidly) A four-wheel alignment took care of that and %95 of the vibrations. $60 well spent and my handling is a lot better.Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
Ah yes.
First check for proper PSI in your tires(all four).
It could be something simple as that, or perhaps a re-balance and rotation for the tires could solve it...
...also, check on the anniversary rims to see if you are missing the "counter-weights." This happened on my GSR rims(other car) and i was shaking at certain speeds and certain speeds only.
1990 Accord Lx F22a1(Daily) SOLD - will be missed
if your shaking problem is coming when accelerating, like 55-75 mph, like mine was, then it might be an axle or two that are worn out. My boots looked fine, but when i checked the axle by tugging, there was Plenty of movement so they were worn out.
im wondering if i pulled a joint out of one of the axles when i was replacing my camber kit and my whole suspension setup to stock.
sometimes i hit a slight bump and the whole car shifts to the left/right.
prior to the swappage my steering was fine...out of alignment...but still drove without shaking or slack.
Originally posted by Losiracer2if your shaking problem is coming when accelerating, like 55-75 mph, like mine was, then it might be an axle or two that are worn out. My boots looked fine, but when i checked the axle by tugging, there was Plenty of movement so they were worn out.-Xavier
Originally posted by 90_cb7if that is the problem, there is a place in town that has a sign in front that says says 'Axles $95 installed'. is that a good deal for axles?
and if you dont like doing the work yourself, i would assume that it is a good deal. if another breaks though you wont have any warranty (unless of course they offer warranty on their axles.)
