Uneven Brake Wear...
    I just replaced my CV's yesterday and found that I have slightly more brake pad left on the driver side than the passenger side. I was trying to figure out do I need to replace the calipers, brake lines, master cylinder or just the pads. Im confused
    My CB For Sale
    im 100% sure that its the caliper slides not the calipers. they freeze up after time. if you are going to replace the brake hoses i would recommend stain-less steel ones(Goodridge). the only time you are going to replace the brake lines will be if they break (rusted out). as for the calipers those will need to be replaced if the piston does go back or if you feel the need to replace them. teh master cylinder will need to replaced if your pedal goes to the floor when you come to a stop. anymore info let me know
      thanks man, i was thinking that was it. I'll keep you posted.
      My CB For Sale
        No I have a bad vibration from the passenger side and when I put on brakes it some what violently wants to pull to the right and the car shakes when I drive now. I just got new tires so they are balanced and two new outter tie rods. I know I need an alighnment but my question is does it sound like my rotors are warped or what?
        My CB For Sale
