Camber for a 3" drop
    I was wondering if you have to have a certian camber kit if you lower you car more than 2.5". Im buying Dropzone coil-overs on dropzone struts. If so what is the best camber kit out there to buy? Also is any body on a 3" in drop right now and is there anything that scrapes like lip, tranny, or exhaust?
    "Up Down, Slide To Slide"
    Members ride thread- ]http://www.cb7tuner.com/vbb/showthread.php?t=63019]
    if u get an anchor bolt camber kit with that low of a drop, u will bang the crap out of ur upper conrtol arms
      so what kind of kit do i need, one that moves with the suspension?
        You WILL NOT be able to properly adjust all of your camber out of the front suspension without cutting holes in the inner fenders for clearance. One of the NW guys had used a sawsall and has adequate clearance now.....but you've got to deal with the holes.
        1992 Accord LX - SOLD
          you need something like this. dont opt for cheap ball joint / anchor kits. just do it right.
          and maroon is right, with a drop that low, you wont be able to correct it 100 percent. but why would you want to correct it 100 percent? you would lose that magical thing called handleing.
            Talk to Phempa. He's got a pretty extreme drop. His coilovers aren't even topped out and his drop is about 3.5 inches.
              well im dropped on the exact same suspension with anchor bolt camber kit
              these guys are right about the a arm hitting the top but what i did to fix that is grind off the part of the a arm that hits which is around the ball joint and after doing that i dotn hit at all and im about 2.5 inches around primesniper is about 3 inches on his and he did the same thing and his car doesnt hit scrape or anything i suggest doing that since it worked for me and him
              CLICK ON SIG FOR MEMBERS RIDE
              "2SIIC"
              Authentic Jerseys for sale
              http://www.cb7tuner.com/vbb/showthread.php?t=188314
                see i wish thay had something like this for the accord^^^^^ thats for a civic. im looking into the SPC camber kit for the front this. but i rather have the one shown above.
                  so is about 2.25"s the lowest you can go with-out hitting?
                    naw dude 2.5 your gonna be hitting especially when you go threw hard bumps on the road you will hear that shit and its gonna bend your A arm and then prolly mess up your alignment bad trust me dude if you want to lower your car then grind the tip of the A arm so it can clear threw after you do that then your set and you wont hit and you can even go lower
                    oh i forgot to tell you dropzone is tight man i have the same suspension setup just with springs my coilovers are on there way and i love it it aint bouncy just stiff enough to give you a smooth ride
                    "2SIIC"
                      thanks for the input i appreciate it.
