I need to change my sway bar bushings, it is very scary to drive with the car pulling to the side when i step on the gas or come off the gas. Anyone knows how to change them. I only have the bolt in the middle left.
sway bar bushings
Originally posted by EXCoupI need to change my sway bar bushings, it is very scary to drive with the car pulling to the side when i step on the gas or come off the gas. Anyone knows how to change them. I only have the bolt in the middle left.
1992 Accord LX - SOLD
They said I needed tie end rods, upper control arms, swaybar, lowerball joint, I brought the tie end rods and had them installed it help alot, but it still does it, it is now more controlable. Brought a lower balljoint but the person that put the tie end rods on said all I needed was new swaybar bushings because all that left of them is the bolt.
probably need new balljoints all around, they prob saw they were ripped and wanted to sell you all new suspension components
You can get polyurethane bushings on ebay, I bought some rubber ones from the local auto parts store
EXCoup, new upper control arms will help a bunch too. Putting those on will give you new upper balljoints (they come already installed in the control arms) and new bushings up above. Parts are cheap enough and you can do it yourself.
You may also need new radius rod bushings. Ditto cheap and easy to install.>>>>>>>>>>>>>>>>>>>>>>>>>>>>>><<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Originally posted by 91accord2dri wanna know where to buy the polyurethane bushing kit.
http://www.p-s-t.com/
http://www.p-s-t.com/sport/sifekpg.html
http://www.energysuspensionparts.com/
http://www.energysuspensionparts.com...s.asp?cat=1004>>>>>>>>>>>>>>>>>>>>>>>>>>>>>><<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
