I have a set of s tech teins and my camber is off about a degree. My first question is do i need to worry about a camber kit. And when i corner will i be able to corner all out or will i have to worry about the tires?
Camber Cornering
Some negative helps with cornering, you may only need a kit to extend the life of your tires because you will notice excess wear on the inside edges of the tread. It would'nt be too bad though with only a degree of camber.
That's why I'm using am Ingalls concentric camber kit up front, and shimmed the upper-rear control arms out with some washers. I drive about 90 miles a day, so I already go through tires pretty quick.1992 Accord LX - SOLD
Originally posted by Cb7shotI have a set of s tech teins and my camber is off about a degree. My first question is do i need to worry about a camber kit. And when i corner will i be able to corner all out or will i have to worry about the tires?
If you want to maintain your tires and decent high speed dynamics, you should get a camber kit. That is unless you can correctly adjust the camber with the OEM suspension components.
When u corner, u will always have to be concerned with your tires, especially if you are cornering "all out." Usually in LHD countries the right side tires wear our first b/c of high speed left turns. (the opposite in RHD countires).
Higher springs rates will also make your tires work harder, thus increase tire wear.DEVOTE
FS: Lokuputha's Stuff
dont worry about the negative camber. 1degree isnt bad at all. just make sure your car is aligned so your toe isnt off. and about "all out" cornering... you wont be able to do that, but not because of the camber. those springs you have are too soft. you need stiff shock or sways to help with that. teins are too soft and youll still get roll. get something like a set of omni's, and youll be riding on rails
Originally posted by DrLove'sKuDangdont worry about the negative camber. 1degree isnt bad at all. just make sure your car is aligned so your toe isnt off. and about "all out" cornering... you wont be able to do that, but not because of the camber. those springs you have are too soft. you need stiff shock or sways to help with that. teins are too soft and youll still get roll. get something like a set of omni's, and youll be riding on rails
lol at the Omin's. They do hurt a bit till they've settled and are adjusted properly. I'd still like a rear sway bar, but they are pretty nice. Especially for $650.Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
Negative camber doesn't hurt the tires as much as toe-out or toe-in would..Just keep your toe aligned like DrLove'sKuDang said, and you'll be okay..
Right now I'm lowered about 2.5", running -3.1deg camber up front, and -1.2 at the back..No camber kit..I LOVE how the car handles around corners..Less camber in the back causes the car to slightly oversteer under hard and sudden cornering..Understeer is greatly reduced thanks to the negative camber, even on wet roads..As for tire wear, so far so good, tires seem to be wearing evenly...
Like everyone said tho, keep the toe aligned..Before this, I was running H&R Sports with -1.3deg camber in the front and a toe-out, and also old bushings, old ball joints, etc. etc..Inside of the front tires wore out so fast it's not even funny
Ronald
