Uneven drop
    Originally posted by gloryaccordy
    My car has that same issue as well, ever since I dropped the car. It might be a worn lower shock bushing, or the car leaning when you park on a curb. There's no way to fix it.
    Seems to happen anywhere I park, so I guess its lower shock bushing. If anything, whenever I do a photoshoot I'll do it from the passenger side
      Originally posted by i97supratti
      How about if your rear driver side has a 3 finger gap, and your rear passenger side has a 2 finger gap? I double checked everything, and they are both installed correctly. I'll probably switch them and see what happens. I'm on koni yellow and neuspeed race btw.
      exact same problem with me
      Burrito Bandidos: It will change your fuckin life
        Well i fixed the problem....Now im dropped and lovin it
          How did you fix it? Like what did you do to get the front low again?
            The silver perch that the spring sits on i had it upside down...so flipped it over and voila 2.2" drop
