Originally posted by 1990HybridCB7
No Power Steering: Is it really that bad?
Originally posted by ehulstx2.....its really not hard to remove it, the only part that needs attention are the threads down under the car.......i just cut the lines they were on and welded the insides of the nuts and made grinded them down for a cap and put thread locker on them and threaded those bitches in....other then that its a breeze to remove, do it or dont its really up to yourself......i personaly like it without it, builds muscle and more control.......
If you try this MAKE SURE you don't go back too far. Kick your key back into the ON position right away. You should only need to back out of it long enough (one second or so) for the engine to stop rotating.
its not that bad, i removed it on my car. it takes some getting used to, and some muscle when you have to turn it from lock to lock or something like that.
personally, as far as handling goes, i preferred it over having power steering. you have a better control over it (IMO) and it's less twitchy (18s and negative camber makes for a twitchy ride at interstate speeds)
I think you quoted the wrong guy Cipher.Metal Metal and more Metal!!!
How much does your wheel/tire combo weigh? Post here!
-=Suicide Crew Member #1 (only member so far)=-
MY RIDE
"I was hoping the Wolverine would finger one of those Japanese girls and then extend a claw into her b hole just for fun, BUT that never happened and I was extremely unsatisfied with the movie because of it." -Macaqueistrong
