finally lowering next week...
    well, i'm finally lowering the car sometime next week. going to DIY with a friend of mine as best we can. renting a spring compressor. and all the other tools that i'll need i should already have. is there anything i should look out for when we go at it?
    First... have some PB blaster on hand for tough crusty bolts and nuts... apply multiple times and let it soak for a little while... it works...just give it time...
    and
    Just be careful of those compressed stock springs... they are evil...
    RIP Lifsatrip7
      Rear shock lower bolt goes through a bushing. The bolt is frequently frozen to the bushing, and the only way out is cutting the bolt heads off, and changing out the bushing. Having the bushings and bolts on hand is good fore-planning.
      The pinch bolts on the fronts can give you grief as well.
      2003 Maxima SE Titanium Edition
      1993 Suzuki GSX1100F 136bhp
        make sure u have some wd-40 on hand
        the lower strut bolts are a bitc* to get out sometimes because the bolts are seized in the bushing.
        replace the bolts and bushings
        make sure everything is tight before u drive off
        if u have trouble getting the front strut out of the fork just tap on it a few times with a hammer or something. it can get stuck in there.
        take your time
        give the new springs/struts about 500 miles to settle out to the final ride height. you'd be surprised but sometimes up to 1.5inches can be realized.
        good luck and if u need any help u know where u can turn to
        My members ride thread
          thanks for all the tips
          where could i pick up new bushings if i need to replace them?
            Dealer.
              Originally posted by SteveB
              Dealer.
              cool thanks, how much do they usually run each?
                Is your dealer open today.....?
                  yes, i can call in and ask them. is there a part number for each bushing?
                    also, can i get PB blaster at my local auto parts store?
                      Is your local auto parts store open today?
                        the bushings are cheap its the bolts that are alil expensive...bout $10/wheel so 40bucks to get all 4 bushings and bolts just went online through rockauto.com
                          would it be ok to lower the rear first, and then the front the next day? or vice versa? if i don't find the time to do both at once...
                            thats what me and williamsvt did^^ we just didnt drive it in between. start spraying all ur bolts now with pb blaster
                              [QUOTE=tanNn2koo]would it be ok to lower the rear first, and then the front the next day? or vice versa? if i don't find the time to do both at once...[/QUOTE
                              Thats what I did.]
