Neuspeed Sport Cup Kit
    I recently bought and installed a neuspeed sport cup kit which is koni adjustables and neuspeed race springs.
    I have a problem though.
    When i took the stock suspension off I noticed not all shocks had the same bushings. The front Left and Rear right both had this BIG bushing that apprears to go to the bottom of the Strut top below those 2 identicle small bushings and is pressed up into the Wide circular opening part to cover up the lower bushing. Honda doesnt know what they are, They are not in the catalog at all. WTF are they?
    I just installed both in the front of the car so that at least part of the car matched. The front suspension works beutifully.
    the rear suspension however is awfull if i use the struts firmer settings.
    it bounces like cut springs on blown stock struts.
    Help!!
    That being said this is an awsome suspension. when all 4 corners are set full soft the car runs smoother than a new stock honda yet body roll is minimul
    I would reccomend leaving the rears at the hight position the come and droping the front down 1 notch to make the car look even.
    also the bracing behind your back seat has to be modified slightly for the shocks to fit and be adjustable
    You take the bushings out of your stock ones and put it on those. The tall ones go in the rear the shorties go in the front. BUt i used my stock ones with no problems at all. DOnt let the bushings confuse you though. As for the setting you have to feel your way out till you feel comfortable though. I turned my dials on the rear and in the front 180 in the soft postion that way its not too hard and not too soft its just right. And yes they do ride comfortable .
      This is what I'll be buying very soon. Can you post some pictures up?
      Metal Metal and more Metal!!!
      How much does your wheel/tire combo weigh? Post here!
      -=Suicide Crew Member #1 (only member so far)=-
      MY RIDE
      "I was hoping the Wolverine would finger one of those Japanese girls and then extend a claw into her b hole just for fun, BUT that never happened and I was extremely unsatisfied with the movie because of it." -Macaqueistrong
        Click my white project link in my sig for this exact setup. I have the neuspeed race springs on the middle perch on all 5 koni shocks. I have suspension shots too....
          Yeah, I knew you had that setup. And H23Accord said it was his best setup. I still don't understand how you don't bottom out. I'm used to really shitty roads and I just can't comprehend not touching the ground once in a while esp if it's gonna lower 2". But if Sparkle runs it no problem where he lives...
          MY RIDE
            hit me on AIM Accord EX SE to discuss installation
              Yea I can cosign on Sparkle's ride being good, no homo.
              Originally posted by lordoja
                what about those extra 2 really large bushings i was mentioning?
                they go in the rear?? so the rear strut mounts have 1 upper and 2 lower bushings??
                  bump
                    I need pics or a diagram to know WTF you are talking about to help.
