Should I get a camber kit???Wait until you lower your car and get an allignment printout. If the camber reading is within .2-.5 degrees of the stock spec (generally 1.0 to -1.0) then asess your need by looking or the next time you rotate your tires. If its past negative 1.5, then it might be a serious thought to get a camber kit.
camber question?
camber question?
My Members Ride Thread
Originally posted by deevergoteYou have to think outside the box to get IN the box!Tags: None
ok, thats the type of info i was looking for, thanks guys, i was a little worried about my camber, but if its not to bad, then thats cool. and ill just have to keep my tires rotated. i had really bad toe before, and ive got pictures that prove it. so i gotta order two new tires for my front wheels unfortunately.
Just to show what some extra toe will do to ya. This was on my car at stock height. Hit something that knocked the toe out a few degrees on each side. Tires had treadwear rating of about 440(high) and had maybe... maybe 1k on them before this. 2-3 hours @ 90mph, this is what they looked like.
ok, so according to the place i need new upper adjustable ball joints in order to have my alignment done. for sum reason that sounds really strange. is that true, and if so, is there a place that i could order them online for cheaper then wut they were going to charge me, 138 bux a piece.
Originally posted by mcdizzleok, so according to the place i need new upper adjustable ball joints in order to have my alignment done. for sum reason that sounds really strange. is that true, and if so, is there a place that i could order them online for cheaper then wut they were going to charge me, 138 bux a piece.
