Front end of my cb7 making noise!
    Hey guys the front of my cb7 is making a noise that sound like two metal pieces rubbing together real hard espeacially when I go into my driveway. I'm thinking that i might have to replace my bushings on the front. Any good bushing sets that are really good value and quality? Give me a hand here guys! Thanks
    it kinda sounds like a ball bearing thats lose or just really needs to be regreased....if the sound has been there for a while then u may need to replace them. but i suggest that u take it to ur mechanic shop and just have to take a look at it.... it should be free.... good luck
    "Fear Nothing For Nothing is Everything"
      question for you..............drive the car straight then move the wheel left and right..........ok if it makes a humming noise on the right side and you are turning the wheel right its the wheel bearing? vice versa on left side.
      AKA:ONEOFFACCORD
        bruce20636, jack up the front end and take a peek at your anti-sway bar bushings --- there are end-links (on the ends, duh) and middle bushings.
        Bet one or more of the bushings are shot --- making noise when going slow into or out of a driveway or other low-speed bump is a classic symptom.
          I figured it out guys it was my tie-rod ends gone bad. when my mechanic took a look at it and touched it it fell completely apart in his hand. that would have sucked if i had kept driving it and it had came apart.
            (deckeda puts away Jr. Mechanic Internet Diagnosis Kit in shame.)
