Help with Drop ideas..
    Aight i want to get a drop on my 5th gen after the winter but i dunno if i want it that bad that im going to invest like 500 bux into it, is their any cheaper set up for like a 1-2 finger gap drop.. because im puttin mah money into alot of diff things and i also dont want to put somtin on thats going to cause the stock struts to blow out, well.. how much would it cost to change the stock struts and shit.. just anyone who knows holla at meh.
    it depends on what your going for thou...
    performance/looks its up to you..
    if your going performance most 2" drops wont cut it on the performance edge not that they dont have any.. IMO
    performance=
    eibach proline
    H@Rs
    Tien
    ect
    looks=eibach sportline
    nuespeed sports i think there called dont recall
    suspension techniques
    any coilover setup
    basiclly u have to be able to sacrifice some to get some..
    if u want a phatty looking drop.. you gotta sacrifice some ride quality if your on a tight budget..
    a good setup for you would be
    eibach sports which are found in the mid 200s
    and tokico blues.. at the same time or later down.. depending on condition of your stock ones..
    again.. as ATX has posted with his experience.. his lil ractive coilovers were bouncy like wow.. lol.. then he added tokico blues.. and the ride is stiffer/firmer..
    so if u deside to upgrade your shocks later down dont think the eibachs are shit.. lol... its just that ur on stock shocks..
    so your still looking at nearly 500 either all together or sometime added up together..
    IMO..
    get the eibach sports.. wait a bit till u have money again and get the tokicos..
    Praise The Lowered...
      if i were u id spend some good money on suspension cuz the roads in michigan suck, if u ever get a lip itll be gone after takin a cruise in the freeway so dont be hesitant when it comes to suspension. i got some springs i wanna put on but not until i get some struts cuz the roads in windsor are like michigan but not AS bad.
      or u can go the badass cheapo way and take out ur springs and struts and it will be dropped like its hot and u will pick up bitches cuz they will think its so low that its a lambourghini........ yaba daba doo
        haha.. i just want to drop it a tiny bit, not that much, its pretty low stock actually, im kinda surprised.. i was considering 1 pinkey drop lol.. would look hella good once i get Lo-Pro's after winter
