Im in the market for buying a type of suspension, cuz my car needs a drop b4 i start moddin it..So whats the best way i can go, i was told since im not going to be configuring my car's drop and shit all the time i should just go with Springs.. But what Springs should i go with??
Type of suspension?
If you wanna go 'inexpensive', here's a list of springs I recommend: Sprint 2.5", Tanabe DF210, Tein S-Tech, ST Speedtech, H&R/Neuspeed Sport. I'm pretty sure you can run them on stock shocks. Other than that, you get what you pay for...
Originally posted by 90AccordBoiIm in the market for buying a type of suspension, cuz my car needs a drop b4 i start moddin it..So whats the best way i can go, i was told since im not going to be configuring my car's drop and shit all the time i should just go with Springs.. But what Springs should i go with??
P.S. Do not cut your springs, your car will even bounce on flat roads.
I'm dropped 2.5" on stock shocks; kmart is dropped 3.0"+ on stock shocks; it's all really just in the spring rates, how you drive and how the roads are in your 'hood. If the spring rates are close to stock you really have nothing to worry about besides bottoming out, camber, and the UCA's clearance...if your shocks are good you can drop it and for a few months until you get GR-2s or whatever...but it's def. not as bad as people say it is, as long as it's not permanent. Plus doing your own install is not that bad; I can do mine alone in ~6 hours or so.
Originally posted by gloryaccordyI'm dropped 2.5" on stock shocks; kmart is dropped 3.0"+ on stock shocks; it's all really just in the spring rates, how you drive and how the roads are in your 'hood. If the spring rates are close to stock you really have nothing to worry about besides bottoming out, camber, and the UCA's clearance...if your shocks are good you can drop it and for a few months until you get GR-2s or whatever...but it's def. not as bad as people say it is, as long as it's not permanent. Plus doing your own install is not that bad; I can do mine alone in ~6 hours or so.
My point exactly.
IMO if you dont have the money to do it right, dont do it. Buy the shocks, let them sit, then buy the shocks, install them both. Otherwise you are doing the job twice and you can possible mess up the suspension system, plus if you are doing this right you will have to get your car aligned twice.
-nick
Installs are easy...seriously like 4-5 bolts a shock and some maneuvering to get them out. All I have are a jack+stands, a ratchet set, matching wrenches and a breaker bar. $60-70 in tools saves me hundreds on labor.
Originally posted by ez8o5just bought some eibach sportlines, now what schocks should i get?
i dont understand how you guys are dropping so much on stock shocks. theyre for sure blown, and sleeves suck ass, i dont care what brand they are. if you must get something and cant afford coilovers, get a nice set of springs. i had speedtechs on stocks and they rode fine... but anything more than a 2/2.5" drop on stocks might cause problems. and you cant get springs that low with stockish springrates, that would defeat the purpose of them... youre just gonna be smackin the arm constantly.
the lower you go, the stiffer theyre gonna get. and gr2's and agx arent meant to be dumped on. if you wanna go real low properly get a set of koni's or a REAL suspension system.
