So me and micksf22accord were wondering if your supposed to have your strut bars pulling the strut towers together or pushing them apart. Or do both ways work?
Strut bar again!
The ebay ones are designed to tighten inward, if you do otherwise it will spin as you drive and probably fall off or some stupid shit like that.
As said before, they're only to keep the two towers in union, and the best way to do that is with a strut bar that's actually designed for your car and is static(unable to be moved). Nuespeed seems to be the way to go, but I think that Fushigi is in the process of making us some cheaper ones, IDK.
When all else fails, test it, see what you like, and do that. Just be careful when you're testing, if the handling is dramatically different it can cause problems(personal experience w/ ST rear sway and removed front).-Jay
wait i seen the megans one, and they seem to be WAY better than the regular ones.
)----------------( *so this is the way? this pulls them in right?
AND NOT
do you guys mean like that??
what are the negative effects of one?? and also, what are the torque specs?
thankshahahahah
^^^^ either way is fine....but having them )--------------(....will fit alot better...on our cars....but having them pushing inward or outward shouldnt matter aslong as u have then on tight ur fine...cus it still minimizes the frame bend..which is the whole point of strut barsSo SIIC...
SoCal OG bitches...
hahah dude...they dont push or pull together, they strenthen the chassis to reduce flex...kinda like putting a piece of wood across a unstable cabinet...What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
