I'm trying to decide which shocks to buy for my 90 accord. Mainly between the KYB AGX's and the Tokico Illumina's, or possibly the Koni adjustables but they are more money, i do not have alot of money to spend. I like the life of the car warranty for the tokico's, but i dont know anything about the KYB AGX warranty. The AGX's are around $100 cheaper. Ive also seen that DropZone has shocks that are specially designed for lowered cars, but i havent heard anything about them. I currently have stock blown shocks and max speed sleeve over coil overs. I like a firm ride and i like being able to adjust the shocks, but it is not a necessity. I also have a H22 swap so my front end is a lil heavier than stock, dont know if that affects anything tho. Anyways, tell me what you guys think. Which ones should i go with and why would you choose it? Thanks.
Which shocks should I buy???
I do believe that this topic has been covered NUMEROUS times. You are going to want to "SEARCH" the suspension forum. It will answer your questions."This is a jaded bunch. To gain notice, you have to challenge conventional wisdom, test assumptions, and ignore the naysayers."
FS Part out thread koni/skunk2 suspension, jdm pole, HID retrofit, Tanabe exhaust
search for each kind of shock you have listed. you'll come accross alot of good results that way.
http://www.cb7tuner.com/vbb/showthre...t=koni+yellows
http://www.cb7tuner.com/vbb/showthread.php?t=21775
http://www.cb7tuner.com/vbb/showthread.php?t=5251
those threads should get you started. I'm sure they'll awsner alot of your questions.
