i did the electro-hydraulic power steering in my cb7 with k24 swap.
i had the high pressure line made, no issues there. plumbed the return from steering rack back into the ps pump. no issues there.
my problem is the 2 extra ports on the rack. 1 goes to the cooler in the front bumper area, and 1 goes to the vss for variable assist. i have a decent leak from trying to loop those 2 ports together and trying to dump them into the return line.
what would happen if i blocked those 2 ports off with some plugs? will pressure build up inside the rack? i tried to loop them and as soon as the pump is turned on, the steering wheel when FULL lock to the right and was hard to turn/not safe. trying to find a clean way to eliminate and make my ehps 100% so i can make a diy on it.
heres a pic showing the port locations.
any ideas?
any ideas?
