5 lug swap with 7th gen parts?
    Long story short, I tried selling the cb9 and couldnt, so I am keeping it. I want to eventually do a 5 lug swap but the local pick n pulls are either too expensive or already looted. Found a local 04 Accord that is totalled and being parted. Guy wants stuff gone on the cheap. Anyone know if these parts will work?
    Ive done a search with no answers. Just the usual oddy and prelude swaps.
    KDI CUSTOMS-AUTOMOTIVE UPHOLSTERY www.kdicustoms.com
    Look at my posts and threads in the statistic section of my profile. You will find how I did my 5 lug swap. I would list them but I am out with family now.
      I used the v6 accord knuckles from a 6th gen, I'm looking at a pic of the 7th gen knuckles and it looks damn similar to the 6th gen. Try it if you can get them cheap enough. The rears I know for a fact won't work...just look at them
      YouTube Clicky!!
        I couldnt find your 5 lug swap in the statistics section. I will look again later.
        Im trying to find alternatives to 6th gen accord, prelude and oddysey since they arent currently available and are usually looted before I can get to the junkyard.
        I found pics of the hubs here http://www.speedyracer.com/2-PCS-REA...Hybrid-Models-
        04 Accord Rear Hub
        92 Accord Rear Hub
        Not sure how accurate they are but to me that looks pretty close.
          I should have been more specific, the spindles won't fit. The hubs, I'm not so sure about. I don't know why I was thinking spindle swap...
          YouTube Clicky!!
            Am I stupid in thinking that I can use the CB spindles and just replace the hubs on the front and rear? I cant remember what all I read from the various conversion threads. Im working on way to may projects plus trying to put a new shop together and my brain is foggy at the moment. Everything is running together in my mind.
            Thanks for all the input so far.
              For rear hubs I would simply purchase new units. There's no sense in getting a used rear hub/bearing from a junkyard that has been sitting out rusting away.
              For the front, I looked into it once and it looked similar but so does a Civic's. My opinion was that the angle of the outer tie rod would be too different. This is something that those who do the Prelude front knuckle swap (and Legend/1st gen 3.2TL from what I've gathered) have to contend with also. On those applications the outer tie rod mount on the bottom of the knuckle instead of the top like other Honda applications. You have to flip the outer tie rods to the opposite sides to use them.
              The 7th gen Accord could use a similar fix to get it to work but the angle is also a little different in this application.
              Since you have a wagon you have a knuckle different from the rest of the CB guys. Your knuckle is designed to house a larger 4-lug bearing and hub up front. Stripped of the hub and bearing it's actually the same thing as '95-'98 Odyssey. You could actually order a new hub and bearing for the front and swap them into your knuckle. It would be just as involved as the 2.3CL ROH swap is for the coupe/sedan guys.
              Let me know if you have any more questions. My recommendation would be to just buy everything new.
                i used 2002 TL front spindles for the 5 lug/big brake/ROH conversion, that was done super fast
                i stayed drum in the rear and used Prelude rear hubs and CR-V drums
                  found the thread and bumped it for you
                    This is basically what I needed to know. Im thinking of just ordering new complete hubs with bearings and keeping my stock spindles since I have to replace the bearings anyway if I use salvage parts. no need to make it harder than it is.
                    Parts list as of now.
                    FRONT
                    95-98 Odyssey hubs and bearings
                    Not sure what calipers I will run
                    95-98 Odyssey rotors.
                    REAR
                    97-01 Prelude non SH rear hub and bearing
                    97-01 CRV rear drum
                    Let me know If Im missing something. I will go to the parts store soon and get pricing and part #s.
                      Well, if you are using the Odyssey front rotors, the CB9 calipers are the correct ones to use, same size rotor.
                      The issue with the wagon rear is the spindle is larger and unique to the wagon. As far as I know there is no 5 lug hub that will fit. Best option is to find a complete sedan/coupe rear subframe, control arms and spindles and swap them onto the wagon. Really not too bad, a couple buddies and I did one in an afternoon.
                      1992 Accord Wagon (RETIRED)
                        For the wagon you only need the spindles not the whole subframe.
                        FA1
                        355
                          control arm spacing is different.
                            By 50mm.
