hey guys, just coming out of alignment and i have a little problem of wich i am aware since last year but never took time to get into it...although now i'd like to fix it
the caster on my car is off a little bit too much on the passenger side, the wheel is pulled back and its out of specs...car isnt pulling at all tho...
i kept my alignment sheets since a couple years back because i like to try different set ups now and then and took a look at them all the way back to 4 years, and back then the caster was perfect, i never got into an accident either...
the caster changed when i installed my h22 2 years ago and i know we removed the crossmember during the process
now i'd like to know if there is some kind of adjustment on the crossmember itself (besides radius rods) maybe we reinstalled it a bit crooked (thinking here that the holes to bolt it up may be slutted a bit from factory or something)? if not is there anyway to loosen up something like the subframe perhaps and use a pry bar to straighten my caster?
has anyone ever got this issue?
and last, in the eventuallity that nothing can be adjusted and i really do have something bent in the suspension, does anyone have the plans to measure my chassis from under the car? i cant find them from my job (im a bodyman btw) all i could find in the program was top view plans... because worst case, ill just put the dozer on the car and pull it a bit but to do that i need the plans
