Sway bar endlink help
    Hey guys I've got everything on my suspension connected besides my sway bar endlink. I can't seem to get the top bushing and collar on top of the bolt with enough room to thread the nut. Any advice? I'm sure if I had a manual it could help me.
    Originally posted by Quashish
    hahaha
    noobs be like where to be buying hella flush yo?
    when you lift the car lift it from the lower control arm so the spring doesn't extend and increase the distance between the sway bar to the lower control arm
    MRT http://www.cb7tuner.com/vbb/showthread.php?t=188701
      put the jack under the control arm just under the lower ball joint. Slowly raise and you will see that you can thread it in.
      Retro!
      Hater
        Thanks.
        hahaha
