shaking when accelerating
    hey guys i have this wierd shaking from the pasenger side only when i accelerate on some roads its not so bad but some it shakes fiercely i checked my axel its fine i changed all my sway bar bushings recently i checked my wheel bearing and seems to be good and i also had my tires balanced and i just wanted to see if i can get someones opinion on what it may be??
    I love my cb7
    How are your motor mounts?
    92ex CB7<-SOLD 93ex CB9shiftingshift73C10
      my torque strut is done for
      I love my cb7
        does anyone know?
        I love my cb7
          Well if your front motor mount is bad then that would be why you are getting shaking under acceleration.
            Just because something is bad, doesn't mean that its the cause of the problem. I've dealt with chasing down a vibration before. Everyone said, "axles, balance tires, alignment, tierods, motor mounts blah blah blah". It ended up being a bad wheel bearing. As I was going through and replacing these parts (the ones that needed to be replaced), nothing changed. Then I installed a new wheel bearing (which was not making the normal bad bearing noise), problem solved.
            To the OP, I'm not saying that the motor mount couldn't be your problem, but don't become convinced that its your only issue. There can be other problems that are causing your vibration. Good luck trying to find the issue.
            Does it get worse turning one direction or the other?
            Is there a noise associated with the vibration?
            Does the vibration go away when you apply the brakes?
              it only happens when i pick up speed fast otherwise its smooth its usually when i enter on a freeway but when i let go of the gas it coast smoothly again i was told a inner tie rod by somebody else but idk if thats it when it does shake though its only on the passenger side and its really bad shaking not like anything i ever felt any car do before
              I love my cb7
                Fix known problems first particularly if they are related to the problem.
                He said he front motor mount is bad.
                  I got the same problem
                    i feel your pain dude its annoying cause ive replaced alot and its still doing it i was told it could be my inner tie rod but idk i guess ill have to try that
                    I love my cb7
                      Sounds like a problem I had when I lowered the car, turned out to be inner cv joints. Sever vibration on passenger side mostly, worst on acceleration, that only went away by sinking the clutch or in neutral. When I checked it boots were in tact but it had some play going in and out where it goes into the engine/transmission. I changed both, havent had problems since
                        it's a bad axle
                          i have the same problem. i agree with the bad axle and i would check that your exhaust system is not loose. i changed all my exhaust mounts and made sure it was right and most of my shaking went away. but i know my axles still need to be done.
                          "Good judgement comes from experience,
                          alot of that comes from bad judgment"
                            Happened to me when I had a bent cv axle. It was a new remanned part too. Also, make sure you didn't throw a wheel weight.
                            http://www.cb7tuner.com/vbb/showthre...=1#post1823428
                            My Custom BB6 Dash Swap Thread
                              well looked into it more my outer tie rod is completely shot on the passenger side imma try that first and see what happens thanks guys for all your opinons if it doesnt work ill try my cv axel
                              I love my cb7
