So i bought these lca's and not sure if i did something wrong but they seem to be longer because my back tires are peeking in like this /---\ , not sure if i need to get toe arms too , any help?
Blackworks LCA's
Originally posted by woody7193 View PostSo i bought these lca's and not sure if i did something wrong but they seem to be longer because my back tires are peeking in like this /---\ , not sure if i need to get toe arms too , any help?
If they cause you to have massive camber then they must be the wrong size. An alignment may be needed, but not if they are to the correct spec. It sounds like they aren't, I would contact Blackworks.'93 H22A 5SPD SE - MRT - DIY-Turbo Sizing
Originally posted by woody7193 View PostSo i bought these lca's and not sure if i did something wrong but they seem to be longer because my back tires are peeking in like this /---\ , not sure if i need to get toe arms too , any help?'94 JDM H22A: 178whp 146wtq
Originally posted by deevergoteIf you say double dutch rudder, i'm banning you...
I know exactly what this means. I bought the same things. They're not throwing massive camber..... There throwing massive amounts of toe. Positive toe I believe. His illustration is a bird's eye view. I was also wondering about his. Hopefully some light is shown upon this. Bump for an awesome question.
Originally posted by 91cb7h22poss View PostI know exactly what this means. I bought the same things. They're not throwing massive camber..... There throwing massive amounts of toe. Positive toe I believe. His illustration is a bird's eye view. I was also wondering about his. Hopefully some light is shown upon this. Bump for an awesome question.
Originally posted by illinois_erik View Postexpect to replace all accompanying hardware such as the toe adjuster bolt (which commonly seizes up and breaks needing replacement anyway when getting an alignment) and surrounding degraded bushings. Obviously an adjustable RUCA should also be in the list to get a proper alignment. So this is definitely not just a bolt on. Function>Form.
Originally posted by 91cb7h22poss View PostI'll have to look into getting everything. It's not really minor either. So thAT has me a bit worried. If the control arms would be slapped on the car would dog walk like crazy. I'm going to look into all the parts tonight and maybe get some links.
So I figured out something, the 90-93 blackworks lca's for the right side where the muffler goes is bent like every other lca, Idk why they sent me the wrong ones i got the 94 and up lca's I got some links from honda tech
Accord 90-93 (Part# BWLC-597PO)Link:
http://www.bwrusa.com/product_p/bwlc-597po.htm
Accord 94-97 (Part# BWLC-598PO)Link:
http://www.bwrusa.com/product_p/bwlc-598po.htm
