So I installed my ingalls balljoint camber kit on my upper control arm. The problem is that it fits about 90% with little play. When tightend, there is no play but the steering feels a bit off. I'm not sure if its my upper control arm or not. I am using the Dorman brand from Advanced auto. I'm just wondering what brand are other members using for UCA's and if they had the same issue.
camber kit with which UCA
Members' Ride Thread :http://www.cb7tuner.com/vbb/showthre...82#post2939682
My CB7 Tribute Vid..https://www.youtube.com/watch?v=XqWFstSzLH8
Track ready EK..https://www.youtube.com/watch?v=IoYKsoL0i7MTags: None
Originally posted by i want my cb9 View Postwhen messing with camber you have to get an alignment, i hope this helps
I also have the ingalls kit, using the oem arms. When reading the DIY's I saw on the subject they said that the slider plates needed to be pressed in, but mine, like your's, fit right in and had a little play. After tightening they didn't move though and I've never had a problem with them. Changing camber has a pretty large affect on toe. So I'd bet its just your alignment.
I wish I could trade my heart for an extra liver, just so I can drink more and care less.
That's one reason why I'm not a fan of the ball joint kits. I don't like the idea of removing the stock ball joints to install them. I'd prefer a quality anchor bolt kit.
Originally posted by crazymikey View PostI had some generic ebay ones in my car. With them installed, they corrected my camber, but the downside was the UCA now smashed into my inner fender all the time.
Yes (and I have).
Honda doesn't sell just the upper ball joints. They only sell the entire arm, with the joint installed. It makes me uneasy to press the joint out. The metal is rather thin, and if pressing the old out and the new in puts too much stress on it, I fear it could fail. I have yet to see that happen, but given the consequences of such failure... I feel it's wise to be cautious.
Interesting that honda would replace the entire arm as well. I can see your point though. Being quite familiar with a press I can easily see how improper removal of the old joint could cause damage to the arm. Using a socket and hammer like I did, I feel there is much less of a chance of damage to the control arm, since the forces are much less than that of a press. I wonder if Honda feels the same way. Maybe they replace the whole arm to reduce the risk of careless tech's damaging control arms, or maybe removing the balljoint all together could weaken the arm.
I have had "reman" control arms that the upper ball joint just falls out of because they were reworked I assume.1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
