ive just lowered my accord, and now am looking into options for fixing camber, i was thinking just adjustable balljoints in the front, but whats the best way in the rear? and is the ball joint up front the best route?
Dealing with camber
You dont need to "fix" camber, negative camber is good for lateral grip. If you are lowering a sensible amount then you will find that you will get somewhere between -2 and -3 degrees, that is a good amount.
Camber doesnt wear tyres either if your toe is straight, so you are best off getting a good alignment, and enjoying the stance and grip of some camber.
I've got some Megan rear upper control arms which are adjustable for camber.
There are lower toe bars available too, but there is also some slight factory adjustment available. Factory Honda suspension only allows front and rear toe to be adjusted.
Up front there are adjustable kits that replace your stock anchor bolts on the UCA's. I had a set on my wagon, and will be purchasing another set for my coupe.
It depends on how the tyre is used, if you are going in a straight line then yes the inner amount of tyre will have more loading, but if you are cornering you will lose that negative camber as the car rolls, maybe to 0 or further, depends how much you have to begin with and have much roll you have.
Originally posted by marcusv8thunder View PostCamber doesnt wear tyres either if your toe is straight, so you are best off getting a good alignment, and enjoying the stance and grip of some camber.
I experienced it first hand that camber can wear tires. /-----\ will wear the insides of the tires. Why would camber matter if it didn't wear tires? I purchased the Ingalls anchor kit, bolt trick in the rear and got another alignment, purchased new tires and no problem since.
Originally posted by marcusv8thunder View PostIt depends on how the tyre is used, if you are going in a straight line then yes the inner amount of tyre will have more loading, but if you are cornering you will lose that negative camber as the car rolls, maybe to 0 or further, depends how much you have to begin with and have much roll you have.
Also, when you turn, the corner that is being compressed "cambers out" (negative camber), while the corner that is unloaded does the opposite. Essentially, you'll STILL be on the inner edges of the tires.
Some negative camber can indeed help with cornering, but it will be at the expense of some straight-line stability. It's really only desirable in a race setting.
