About to do some suspension work..
    I'm about to do new inner and outer tie rods and new axles anything else I should do while down there?
    I'm also going to pick up some sway bar end link bushings because the old ones are cracking and smashed.Should I do energy suspension bushing or moog bushings?any difference?
    Car audio classifieds...
    http://www.caraudioclassifieds.org/f...ferrerid=12120
    Youtube page http://www.youtube.com/user/blackoutt334?feature=mhee
    Lower ball joints, for sure. If you're going to do brakes anytime soon then now is the time for those as well.
      make sure you get an alignment after replacing the tie rod ends as well so you dont mess up your tires
        I used energy on mine. I like them so far, no issues. You should make sure you also do the main sway bar bushing, not just the links. Maybe the upper ball joints if you can swing it. Those are easy enough to do while your in there.
        "Good judgement comes from experience,
        alot of that comes from bad judgment"
          Wheel bearings and roh conversion uca and lower ball joints.
