Hey I wanted to lower my car... So what is everything I will need to lower it 2 inches??? Do i need a camber kit if lowerin 2inches? can somebody recommend some namebrands for the coil and springs if thats all I need??
Lowering car help
ok well first thing is first....what u get is what u pay for. either skunk2 springs or H&R springs are good. KYB or KONI struts u may wanna use. and with 2in drop no camber kit is needed. i dropped my car 3.5in and i do not need any camber kit. only like a 1degree camber. not bad at all for 3.5 soon to be 4 in drop. i got skunk 2 coilovers and kyb gr-2 struts.
Originally posted by accrdpowerok well first thing is first....what u get is what u pay for. either skunk2 springs or H&R springs are good. KYB or KONI struts u may wanna use. and with 2in drop no camber kit is needed. i dropped my car 3.5in and i do not need any camber kit. only like a 1degree camber. not bad at all for 3.5 soon to be 4 in drop. i got skunk 2 coilovers and kyb gr-2 struts.Last edited by Adam91AccordLX; 03-26-2005, 01:37 PM.
Great site for your questions:
http://www.cb7tuner.com/vbb/showthre...ate+suspension
Also what you need to lower the car is:
-Springs
-Shocks that can handle the spring rate
-Camber kit depending on drop
It is true you get what you pay for. Let it also be known that a suspension's ride quality and handling is subjective and based purely on opinion. The thread above should help you in your search and answer questions I did not answer here."This is a jaded bunch. To gain notice, you have to challenge conventional wisdom, test assumptions, and ignore the naysayers."
FS Part out thread koni/skunk2 suspension, jdm pole, HID retrofit, Tanabe exhaust
Originally posted by Adam91AccordLXSo how is the ride with the skunk 2 coilovers and gr-2 struts? Iam looking more for comfort than performance. Think those will meet my need ro is there better ones I can get for a better price for comfort and less performance.? Iam looking for a good price and comfort.... Got and picks? Thanks for your help
the ride is real good...a little bouncy at first but after 800 miles it is alot better... i do not have the struts on actually...and the ride is better than expected. Def get skunks or H&R! hope that helps. skunks are expensive but they r well worth the extra money
