Location of rear lower tie bar
    I am wondering where I'm supposed to install a lower strut bar (or tie bar) for the rear suspension. It's a megan bar (ebay) and didn't come with instructions. I got the front and rear upper, because they are kind of self-explanatory, but I am unsure of where to put this one. I am guessing it would be here, please let me know if I'm right or wrong.
    If that is where it is installed, how should I go about raising/supporting the car? Can I put the rear-end on ramps, or will the car fall apart after I remove those bolts? I don't want to get my self killed or break the car trying to put on a strut bar, especially this piss-ass little one.
    thats right, but dont put it on ramps, jack it up and put stands...so the wheel will freewheel
    take one end out first then do the other side, if it dont line up again use a rubber hammer to get it alighned...its easy.
    Retro!
    Hater
      Cool thanks, where should I jack the car though? If I put the stands under the jack support thingie (?) I'll have to place the jack elsewhere. In other words, where is a good spot to jack up the car, besides the jack points at the 4 points behind the front tires and in front of the back tires?
        put it up on jackstands right b4 the back wheel on the jack thingy...if ya do it when the car is level it lines up better, trust me...took me a while to dfigure out why i coudlnt line the bolts up...and dont worry, it wont fall apart on ya!
        In memory of Jameel Johnson 4.30.05--You will never be forgotten...
        MY Car
        HydroDunk Mixtapes...check it out
          right right i understand but where should I place the jack since the rear jack pints will be occupied by stands?
            put the jack on the tow hook 1 by muffler 1 at same place on other side
            www.2camcrew.com
              git r' done!....... -justin-
              MY SH!T FOR SALE!
              H23A1 (60,000 miles)
              tranny (no grinds)
              ECU
              DC header w/ heat wrap
              full exhaust with angled N1 Canister....
              $1000 obo delivered
              SOLD!
