Acura CL 97 Front Springs on cb?
    hello everyone, i have scored a set of eibach sportline on an acura cl today. they look really similar.. same lenght.. someone know if this right fit on our cb?
    As far as I know they should work!
    92ex CB7<-SOLD 93ex CB9shiftingshift73C10
      Wht about the struts?
      Will the struts and springs bolt up 2 the cb?
      OP GO BACK AND GET THE FRONT SWAY BAR. THEY BOLT UP. ONE IS HOLLOW, ONE IS SOLID.
        the sway bar on this acura cl?
          i think this 97 cl have eibach pro kit on rear... the spring look similar but not sure if they fit. for front they are bolt one. someone know if this fit?
            IIRC, the 97-99 cl use the same shocks and springs as the 5th gen accord which will work on our 4th gen.
              humm ok just because the 2 ends on the spring on cl look smaller on each end the end is like a bowl.... our are same size all long.. this is why im confused...
                I was reading through this thread and was getting ready to same the same thing! Seems you have beat me to it lol
                To the OP: Yes you should be just fine! Just remember this:
                90-97 Accord Susp parts all fit
                92-01 Prelude parts (4 and 5 Lug ROH conversion)
                97-99 CL (to include the 4 lug ROH conversion)
                This may be more than what you asked for but I hope this helps you some
                The CB7 Collector.
                Team Kindred Impulse Member #3
                92 LX Coupe F22A1
                2013 Toyota Corolla S
                92 EX Sedan F22A1
                Do you really need to make a thread asking if having your car like this /---\ will cause uneven tire wear? Try walking like that for a few weeks and see if your shoes wear funny! (hint: they will.)
                  I was told by tippy that the 1997 cl has a hollow ssway bar, and the more fancy level has a solid bar.
                    Now I am gonna go have to look into that!!! >.<
                    The CB7 Collector.
                    92 LX Coupe F22A1
                    92 EX Sedan F22A1
                      Ya man grab that shit. I gotta go back 2 my yard. I want to start hookin my suspenion up. Nothing fancy. Imma try and use all oem parts.. like the vigor rear sway, cl front sway or w/e. Mix match them up. When done. I should have a more stiffer suspension.
                        nice bro im traying to do that my self 2 i just dnt knw where to get cus i got a dx so i wanna do a rear disck bigger brake in the front and get sway bars for the rear but is in it bigger the vigor one?? dnt knw
                        paypal info:leonardorivera50@yahoo.com
                          I have to put a list together, and see what actual suspension parts ill need.
