I have a 1993 coupe that has been 5-Lug converted in the front using Odyssey knuckles and the whole shebang. I've had a knock for a while, and I assumed it was my lower ball joints. Today I install new ones (OEM), and a little greased leaked out on the side that sounds like it has a mild knock. I doubt if this is the culprit. I have a SPC ball joint camber kit, and I believe everything is tight. It's a mild knock, and I only hear it over little bumps and ruts. When I hit a big bump or pothole, it sounds normal.
What going on?
What going on?
