I recently installed a set of Skunk2 coilover sleeves on my cb7. The ride height in rear is excellent (tucking a little tire) and there is still room to go down if I trimmed the perches on the damper. However, with the front sleeve perches spun all the way down, I still have about a finger gap between the tire and fender. I know I can remove the locking collar from the sleeve to get a little more drop, but has anyone ever tried running just the spring directly on the damper perch without the the sleeve? I realize I may need some sort of a bushing to center and level the spring on the perch. I am running Koni STR.T dampers BTW. Any thoughts?
Really wish the front springs were like an inch shorter...
Also, does anyone know the front spring height for the Integra coilover kit? I know the spring rates are the same 10kg/mm as the accord kit, but if they were physically shorter, that might be another option.
