Hey guys. I had an old thread about the extended top hats I was having made. Well I got them all done and installed the front ones. I have not got around to the rears yet. The car rides better now except when I hit large bumps and the upper control arms contact the strut tower. I am still on OEM springs that are WAY to soft for how low the car is. I have since ordered some stiffer sleeves that should keep the suspension from traveling quite so much. Here are the pics from start to finish.
Drawings for the welder:
OEM strut mounts after extension pipes were welded in:
Grinded the welds down and painted:
Enlarged the strut tower hole slightly:
Assembled strut:
Installed in the car. Barely clears the hood
Front sits a little lower now. It was definitely sitting on the shock body before extending the mounts:
Assembled strut:
