Ebay UCA w/ ball joint quality
    Whats up guys. I just did the 5 lug conversion on the front of my 91. And after i adjusted the toe, i noticed the change in camber from the 2000 tl spindles i used. Also the UCA smashes alot worse now. To get to the point. I have ingalls abj's and want to go back to the oem and found them on ebay for $51 a pair. From worldsuspention. They look right and seem ok. Anyone know if they are crap and if i can get them somewhere else and not spend 70 bucks each. I almost cant drive with two people in the car. Lol. Damn mass roads.
    Thanx.
    "Good judgement comes from experience,
    alot of that comes from bad judgment"
    You get what you pay for.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      that's one part I wouldn't cheap out on, I would buy oem or napa, the ones I got from napa are beefier then oem, and have a 1/8" thick ring around the ball joint to hold it in better
      PSN ID's:Tidashoni
      1992 Accord EX Coupe
      My FS Thread
      Boosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
        Save your money and get quality products when it comes to your suspension. The last thing you need is for you to be driving and the balljoint comes loose from the UCA resulting in an accident.
        | Cali Accord Meet | FatFourCustoms | HS4Lyfe
        Do It Once, Do It Right!
          Thanx guys. Thats what i was wondering. They say that they are oe quality but thats them. i really only need the ball joint. So i can lose the tall ass ingalls bj. I guess ill be picking some up from AZ. Duralast or doorman?
            You may want to check out TASAuto.com they have what you are looking for for a reasonable price
            The CB7 Collector.
            92 LX Coupe F22A1
            2013 Toyota Corolla S
            92 EX Sedan F22A1
              Napa= good aftermarket quality parts
              Tasauto= good aftermarket quality parts at 3 times the cost of napa
              Just do what PR CB7 said.
                I found a set on summit racing for $75 for the set of dorman
                  Even if you you bought the full restore kit?
                  The CB7 Collector.
                  92 LX Coupe F22A1
                  92 EX Sedan F22A1
                    reboxed ebay uca's
                      Originally posted by bobbycos View Post
                      reboxed ebay uca's
                      I used the part numbers to order them. I looked at the expensive one, got the pn and searched that, i figured that couldnt fail. Each brand and manufacture uses different pn's i thought. correct me if im wrong on that
                        get the moog ones. a little expensive but not as expensive as the dealer ones.
                          i used to work in auto parts and i have seen alot of different brands that were the exact same part in the box (supplierwise)
                          moogs are different as most of their stuff they make themselves but there are certain parts they carry are OEM rebox
                            Honda doesn't sell the upper ball joint without the UCA, so personally, I wouldn't feel very comfortable replacing JUST the joint. People have, people do... I just wouldn't.
                            And are you replacing the "tall ass" Ingalls joint because you whack your fender? Will you be running with no camber correction, or switching to an anchor bolt style kit? Because even with that kit and a stock ball joint, you'll hit.
                              yup, just take a hammer to the inner wheel well and smack where you can tell its hitting
                              PSN ID's:Tidashoni
                              My FS Thread
