So I replaced my front rotors, brake pads, did my suspension front n rear upper control arms, koni shocks, skunk 2 lowering springs, tie rods, new axles, new tires(balanced), alingment..I want to know why when I brake kinda hard from like 60mph my steerin wheel shakes.. is it my rack and pinion? Has this happen to anyone? Thanks
steering wheel shake
Originally posted by drew12000 View Postusually when you this happens it means your rotors are warped. one of the reason they warp is from over torquing your lug nuts.
Originally posted by marcusv8thunder View PostIve not heard this before how true is this?
Also a good thing to do an all around suspension check as mentioned above.
tierods (inner/outer)
ball joints
control arms
shocks
rack and pinion
etc..
Wow that must take some MAJOR torque to warp a rotor at the lug nut???? Def sounds like something brake related since its ONLY when your braking. Take it to Midas and they should be able to look at the rotors on the car, the machine that turns the rotors does so on the car so they should be able to check and let you know with a minimal cost to you.
How long have your rotors/pads been on? It can take a little while to wear-in new pads and rotors. If you hammered on them from brand new, you may HAVE warped a new rotor especially if they're standard NAPA or AZ replacements.
Next, No fluid leaks or CV grease on the rotors? Check for grease especially if you have drilled or slotted rotors, as the brakes heat up, the grease runs out of the slot/holes in that area and you'll have what drives like a warped rotor. You should clean the rotors well before installing anyway as they're usually coated with some sticky/greasy crap (causaline?sp) to prevent rust while in storage. 000 Steel wool and brake clean work great to remove any grease/glaze.Last edited by 9threeEX; 05-24-2011, 02:13 PM.93 EX Arcadia Coupe, 5spd, f22a6, strut bars, 2"drop, baer brakes, ingalls camber kit, tokicos w/ eibach, K&N, 205s / 16s
You can easily warp your rotors, even new ones. It's happened to me. When you get new ones you should have them turned (mildly) while on your car. And you should also do this instead of buying new ones.
Also, it is a known fact you can warp them from over tightening lug nuts, although I'm not sure about this happening on CB's.
Here, don't take my word for it http://newcarbuyingguide.com/index.p...318/event=view
Or you can read this article which says there's "no such thing as warped rotors" http://www.examiner.com/auto-in-orla...d-brake-rotors
Anyway you look at it though, it is the rotors that cause your steering wheel to shimmy when braking.Last edited by 4CYLPOWER92; 06-13-2011, 12:36 AM.
Just like eveyone has been saying, its mot likely warped rotors. If i where you the first thing i would try is to have the rotors turned and while you are doing this check the front end. This can be done by jacking up the front end so the tires are off the ground and shake the tires side to side, this checks the inner and outer tie rods, next shake the tire up and down this checks the hub bearing, and finaly put a pry bar under the tire and push up and down if the is slop here then you have bad ball joints. Hope this helps.
